Posted by smoknbs on August 02, 2010 at 16:46:56 from (97.83.75.69):
In Reply to: MD Linkage posted by David Boelman on August 02, 2010 at 15:19:29:
lever must be foward to start on gas . have lever forward and open gas , then check for gas at carb by opening bowl drain ,the check for spark , if mag ,unhook gounding wire from mag to rule out the switch on the manifold .----
anyone reading this or if you know some one with an MD , tell them to drain the carb for winter/long term storage . this spring had to put new float in beause the old cork float had the coating ate away and swelled up to the point the float was sticking to the sides of the bowl !!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
