The rectifier bridge is a little larger in the 15/17 SI models than the 10/12 SI ones. Also the rear bearing has a little more grease capacity in the larger units.
The rectifier bridge from the 10SI should bolt into the 15SI unit. It will not have as much cooling capacity but for what you are using it for that would not be a problem.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
