Re: 1947 M carb
Posted by pete 23 on August 09, 2010 at 20:13:32 from (173.87.8.216):
In Reply to: 1947 M carb posted by J.D.HEICHEL on August 09, 2010 at 19:21:37:
You have a couple of different things going on here. Float may be set too high, but most likely the needle and seat is leaking. That is a constant problem with new parts now days. Float could be hanging up on sides of bowl, pin could be too tight in float hinge. Far as spitting and sputtering, might just be you need to back out the load adjustment. That is the needle on bottom. Just rev engine full throttle, screw it in until it starts to lean out and then back it out until smooth, and give it a half turn more out. For the leak, I always coin or stake the seat but then the guy who repaired it for you should know about that. Although, leak could be just a little crap that got under needle, make sure you have good screen in sediment bowl, or the proper inline filter, made for gravity flow systems.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
