Thats the sign of a weak pump but it usually takes awhile to slowly wear down. Air leaking past the pump shaft seal. May take a speedy sleeve to fix. A lot of times it the seal that goes from the pump to the transission allows air in. Many people run an extra 5 gal. of oil in the tranny to cover the seal. I have to and it doesn't hurt your tractor. Most likely something gumming up and blocking a valve or a popoff maybe has something stuck under the ball.
The settling down could be leaking pistons inside the cylinders maybe the valve spools sticking and not centering like they should. Does the steering work ok? Sometimes it is just a process of elimination and checking pressures and flows. Try some things and let us know. Someone with knowledge will come along and trump my post. good luck.I would rule out everything else before buying a new pump.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
