You will need either a separate belt driven pump, or to use the existing system, you will need a "priority flow divider valve". To use the PFDV, which is the most common and easiest way to go, you would plumb it in the pressure line coming out of the pump, with the "priority out" going to the steering and "secondary out" to the existing system. What this does is assure that even when idled down, you do not loose your power steering. It can however rob enough flow from the rest of the system that when idled down, your 3 point or fast hitch will operate slow, or not at all. My 240U will loose flow to the 3 point unless I am at about 1/3 throttle or higher.
I have seen PFDVs at TSC and you will need one sized to your system with probably about 3.5 - 5 gpm to the priority port.
This post was edited by IH fan at 10:12:13 08/11/10.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
