Is your timing 180 out? If you removed your spark plug wires for painting you may have installed them incorrectly. Not sure how much tear down you did, but if you have suction your valves are most likely in time and with your plugs being dry, most likely a gas problem.
Have you tried starting fluid? If your main jet is adjusted incorrectly that could keep gas from getting to the plugs. Starting fluid should get their either way as long as your throttle is open. If it pops off with the starting fluid then something is messed up in your carb.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
