Most likely the throttle shaft is not installed correctly. This could also be the reason it was so difficult to bleed.
The governor will always try to move the metering valve to the low idle position. The throttle shaft needs to put pressure on the springs to be able to increase the speed. If not installed properly it will move the arm to the rear but not to the front.
When you take the cover off to check it make sure that the throttle will increase pressure on the springs and more importantly that the shut off lever will move the metering valve to the shut off position.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
