It sounds to me like the pilot bearing on the mainshaft is worn enough and/or corrosion damaged and the cause of excessive noise. Popping out of 4th is what leads me in that direction.
You can remove the belt pulley or cover plate in 15 minutes and find out what you've got in there. Once off you can put your hand in and see if there's noticeable play between the mainshaft and the input shaft. Also you can determine what level of corrosion damage from the moisture. Sometimes the get a little surface rust on the gears and sometimes a lot and sometimes not at all.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
