Posted by Tom Fleming on August 20, 2010 at 19:37:44 from (206.193.253.243):
In Reply to: F20 Starting troubles posted by Jay Snyder on August 20, 2010 at 19:13:00:
Sounds like your timing is off. Get #1 cylinder on TDC for the compression stroke. Take #1 plug out, and crank over with your thumb over the plug hole. when you feel it pressure up, you are on the compression stroke. Use a wire in the plug hole to determine when you are on TDC.
Now, take the cap off the mag. Is it pointed at #1 plug? Did the mag impulse just trip when you got to TDC? if the answer to these is NO, then your timing is off and will produce the symptoms you are describing.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
