Posted by pete 23 on August 25, 2010 at 10:47:06 from (173.87.8.216):
In Reply to: 240 utility hyd issues posted by Vally Farm on August 25, 2010 at 09:06:03:
I think you have a plugged orfice screen in the regulator valve assembly. Valve block with four bolts on top. Orfice screws in with screwdriver slotted head. Orfice supplies regulator piston fluid to depress ball unloading valve below piston for low pressure standby. If screen is not broken you can cut end off to clean up and just roll it up again and reuse. Note, strong spring under cover, I use a couple of longer bolts in corners to assemble. Also, 0-ring on the regulator piston will need replacing. Far as adding another valve, should be no problem to add, just finding one from salvaged tractor, one from several different model tractors should fit.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
