Posted by IH fan on August 25, 2010 at 11:57:28 from (70.253.111.148):
In Reply to: 240 utility hyd issues posted by AL Farmall Boy on August 25, 2010 at 09:06:03:
If it blows fluid out the vent and it's not overfull when cold and you check it, it must be getting air in the system from somewhere. First thought would be pump shaft seal, but with a new pump and nothing changed, that's out. Next would be sucking air from the reservoir due to the suction line not being below the oil level, or a hole in a line or loose fitting. You would think it will leak out when not running then, but not always. Something in the relief valve block like the other post is also a good possibility.
This post was edited by IH fan at 11:58:44 08/25/10.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
