Re: Hydralics
Posted by IH fan on August 27, 2010 at 05:43:43 from (70.253.111.148):
In Reply to: Hydralics posted by Spotted Horse on August 27, 2010 at 04:30:54:
Right side of the tractor where you place your feet... so these are not the valve handles that are part of the tractor and located on the right side of the dash? If they are part of the loader, places like TSC have replacement valves for loaders and handles that fit, if you want to relocate the valves. As for increasing the "pump power", the only way to do that is with a higher pressure relief valve. If you are using the tractor pump, I wouldn't do that as you may go over the rated pressure of the pump.... maybe a little would be okay, but not much. I'm not sure where the RV is on the 300, I think it's in a block on the tractor valves under the dash, but it may be possible to shim the spring to increase the pressure. Increasing the flow with a bigger pump would make it operate faster and increasing the pressure relief valve will increase the lift weight or capacity.
This post was edited by IH fan at 05:45:32 08/27/10.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
