Re: 100 jumps into 2 gears at once
Posted by mkirsch on August 30, 2010 at 06:13:43 from (64.80.108.57):
In Reply to: 100 jumps into 2 gears at once posted by couv on August 29, 2010 at 18:55:03:
The "weld & grind the end of the shift lever" only happens when you're shifting.
If the tractor is popping into two gears all by itself while you are driving along, it is something else.
Frankly, I have never heard of such a thing happening before, so unfortunately I have no suggestions.
My gut feeling is that it's a MAJOR problem. Bad bearings or something, causing misalignment which causes the slider gear to "walk" into 3rd.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
