Posted by Leo Davinci on August 30, 2010 at 06:38:01 from (72.237.59.186):
In Reply to: Re: F-340 Brakes posted by rustyfarmall on August 29, 2010 at 11:16:54:
I guess the fast wear comes because I ride the brake downhill to avoid having to use a slower gear. However, even when properly adjusted, this tractor seems to have weak brakes if it is attached to much of a load, especially when attempting to stop while backing down hill. My M does not seem to suffer from either problem, and it also has disk brakes.
I'd also like to add that I "adjust" the brake by using a lathe to remove material from the inner contact edge of the outer brake cover, effectively reducing the space around the disks until they almost touch. Once reassembled, I only turn the adjuster ball nut to "fine tune" it. This method maintains the proper "geometry" for the linkage inside for maximum mechanical advantage to the operator for easy braking. It works great for a while--but not for long, and to lesser effect in reverse.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
