Engine/Water Pump Noise has been identified and fixed. Apparently one of the bolts on the pump wasn't tightened all the way, but the rest were. THat was causing the funny sqeaking/rattling noise, as well as a small leak. We tightened all the bolts, and fixed the problem.
The only issues we're having now at the moment is the starting switch not working as described above. It is as if the key switch wasn't even hooked up. We are having to jump the starter directly to the battery to start it right now. I will check the terminal on the relay tomorrow as you were telling me to do. I have bought 2 brand new terminals and neither have worked so far. It has to be something else because there is no way that both of them (came from 2 different places) are bad
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
