Re: oil pressure on 1949 M farmall
Posted by Theman on August 31, 2010 at 13:26:26 from (65.198.133.254):
In Reply to: oil pressure on 1949 M farmall posted by james1794 on August 31, 2010 at 12:36:16:
The filter is downstream of the oil pump and only sees a portion of the oil as it flows through the engine (bypass system). The pump is submerged under the oil level in the pan making it difficult to lose prime. Unless you're hearing knocking before the gage is reading low, I bet you have pressure way before it registers on your gage. Could be air in the line, could be a gage problem, or it could be a weak pump. Take the oil line loose from the back of the gage and crank the engine. If oil comes out, you need to replace the gage or live with it being slow. I'd advise replacement with a known good gage before tearing into the engine.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
