Posted by JoeVT on September 01, 2010 at 09:14:40 from (208.65.163.217):
In Reply to: Pump update for AndrewZ posted by Paul Shuler on September 01, 2010 at 04:41:47:
The rebuild kit is just gaskets and seals. It wont help the movement in the drive shaft. As Jim suggests, check the brass bearings for wear. My pump is currently apart, i can mike the bearing when i get home tonite and report back if needed. Also check that the drive shaft has the proper bearing. The bearing for the drive shaft is longer than the bearing for the pump gear. It's remotely possible that the pump could have been serviced in the past and the wrong bearing installed. But i would think if it had the wrong bearing it would have done a lot of damage to the gear teeth.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
