Yes, the quality of the bearing was also mentioned by some as a possible reason for the short life. Other thoughts expressed were that the steel bearing may not have been a true thrust bearing but more like an axial bearing. Others stated that side to side alignment may be more critical than for the graphite and if the yoke is not properly aligned failure would occur more easily with the steel bearing. Also on the forum someone posted a picture of an interesting arrangement but no one was witness to how it was actually installed. The picture taken through the inspection hole in the bell housing showed an original graphite bearing housing in the yoke and a steel thrust bearing in front of the graphite housing, which no longer had any graphite extending out of its housing. It looked like the steel thrust bearing may have been "floating" on the drive shaft in front of the old graphite housing, which was only used to push the steel thrust bearing against the fingers. This arrangement was reported to be working OK. I assume the thrust bearing had a collar through its center. If the collar just fit loosely over the drive shaft, it would move straight fore and aft on the drive shaft and may be a way to overcome any alignment issues.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
