Had a young mechanic doing a valve job on a 560 gas one time. He drove out the guides and mushroomed the driver so it made some of the bores in head larger. We reamed it out and found larger O.D. guides and put them in. Often wondered what the next guy would think when he came across this head. Far as valve seals, I am a real believer in them even on these old engines. What happens is as the rocker arm bushing and shaft wear a lot more oil is thrown on the valves and there fore you can get that smoking situation when you first start up. May not change overall oil consumption or then again it may. IH had two suppliers of rocker arms for the 4 and 560 gas engines.. The companny all of a sudden had some realy smokers , oil burners. Co. found out that one supplier was not pinching the oil groove on top of rocker arm down so valves were flooded with oil. Amazing how much oil can go through a guide even when they are new. Had to pull head to clean up all the carbon, If I remember correctly, I pinched the oil groove to specs, installed perfect circle valve seals and that tractor was fine for many, many years.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
