Which engine is it? No1 piston should be near the radiator and you remove that sparkplug. Then hold your thumb over the plug hole while a helper hand cranks the engine until you feel pressure against your thumb. Take along a long plastic straw and once you feel that pressure drop the straw on top of the piston. Then you watch the straw rise as your helper keeps slowly cranking the engine. When the straw quits rising your No1 piston should be at TDC on the compression stroke.
Don't forget to remove the straw and pull the distributor cap and see where your rotor is pointing. My manual has the 301cid engine used in that combine. The firing order if its a four cylinder engine is probably this: 2-1 4-3 If the rotor turns turns CW
Your can follow that plug wire from the distributor to the No1 sparkplug to verify it is No1. If it is the No1 plug wire and the rotor is way off you need to remove the distributor and rotate the rotor so it is at the No1 plug tower which is about 1 o'clock and reinstall the distributor. Hal
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
