When starting, the battery voltage is dragged to 10.8 to 11.5 volts with a good battery. In cold temps, this can be 10 volts, and it also assumes good sized battery cables. When the resistor is in use on a 12v resistor required coil, or a 6V coil, the lowered voltage is reduced to the point that spark is compromised. Thus a resistor bypass puts puts at least 10 volts into a 6v coil making great spark when needed most. When the key is turned to run, the coil is again given its rated voltage. When a 12 no resistor needed coil is used this advantage is just not there. It is commonly used on automobiles and has a history of being a standard method of increasing starting reliability. Jim
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
