Posted by John T on September 05, 2010 at 13:12:00 from (66.244.97.31):
In Reply to: battery starting trouble posted by caryfarmall49 on September 05, 2010 at 11:49:58:
Its pretty fast n easy n usually free to do A LOAD TEST on that battery which is whats really needed. In the event it tests okay Id remove, clean n wire brush, n re atatch each n evey battery n ground n starter n switch connection and insure the ground is to a good solid frame member NOT any thin wimpy rusty sheet metal. It depends on the charger but a slow low amp charge using a 12 volt charger could work just keep an eye on it to avoid overcharging i.e. too much bubbling and outgassing and/or excess current draw. Of course (if the battery is okay???), the starter itself or the switch may be at fault but Id try the above first ESPECIALLY the battery load test
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
