Posted by RegularJo on September 09, 2010 at 13:19:57 from (24.158.60.32):
I’m having issues starting my ’28 McCormick Deering 10-20 when hot. The tractor can be difficult to start when cold also, but it’s almost impossible to restart when hot. I initially suspected coil or condenser trouble, but I’ve checked spark on all plugs when hot and receive a nice, fat, blue spark at each plug. I’ve actually had two magnetos on the tractor and have experienced the same problem with each one. Originally I had an F4 mag but replaced it with a rebuilt E4A for originality purposes. I set the timing with number one piston just a hair past TDC to prevent kickback as I do on all my other hand cranked tractors.
I’m now wondering about the valve clearances since I’m having the most difficulty when hot. The valve clearances are set at 0.011 hot per the owner’s manual. To me, this value seems a lot lower than the clearances I’ve seen in other IH engines. What valve clearances are some of you running in your 10-20’s?
Any other suggestions as to what else may be causing the hard starting issue are welcome. Thanks in advance for any help!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
