Posted by IH fan on September 10, 2010 at 13:03:19 from (70.248.16.1):
In Reply to: IH 240 Steering Issues posted by John - OH on September 10, 2010 at 06:48:52:
I would check two things... the worm gear set-up in the bolster and the keyway in the steering arm. If the keyway is wallowed out, there might still be enough friction in the tapered shaft/steering arm for it to steer when steering is easy. There is a Woodruff key in the shaft/arm and easy way to check it is have someone turn the wheel and if the nut on the bottom of the shaft turns before the arm moves.... well, it shouldn't do that. If the steering shaft going into the bolster turns, but the nut on the bottom doesn't turn, it shouldn't do that either.
This is assuming it is an International and not a Farmall. Seems to be a weak point on these tractors.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
