Posted by Owen Aaland on September 10, 2010 at 15:32:52 from (65.165.246.101):
In Reply to: 1256 shifting problem posted by pete 23 on September 10, 2010 at 15:15:57:
Since you are not feeling any detent when shifting into gear the range transmission cover and the linkage under it is good place to start. Most likely you have a broken roller allowing the detent spring to fall off. If the reverse lever moves in the cover rather than just turning you may need a rebuilt cover.
There may be too much wear in the linkage at the shift lever. As the reverse and high low lever wear on the sleeve they are mounted on they start to twist rather than just rotate on the sleeve. This can cause quite a bit of lost movement at the shift cover.
Check the rest of the external linkage for lost movement. A little extra play in a few places starts to add up.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
