Posted by MeanGene1 on September 11, 2010 at 07:34:48 from (209.148.104.117):
In Reply to: New Owner of 1966 140 posted by stromboli1025 on September 10, 2010 at 20:17:35:
First thing I'd try, as you installed new points, is to crank it with the cap off (probably need a helper or a remote starting switch) and see if there's a series of sparks at the points as it turns- might just need a points adjustment, might be a touch of oil on the points, etc. If you've got correct gap and sparks there, the primary side is working, then you work upstream to the coil, etc. Many times a bad coil wire will snafu you, but as it was OK until you changed the points, I'd bet on that, pretty common
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
