Posted by Jimb2 on September 12, 2010 at 18:33:20 from (99.240.236.11):
In Reply to: 574 Throwount bearing posted by Justin Kuck on September 12, 2010 at 17:44:59:
Hi Justin, depends on several things, is there a loader on the tractor? Do you have a good work place, level floor to work on? Proper floor jacks and splitting stands and tools.On both sides of the front axle drive a block of wood between front axle and boltster to prevent front from tipping. If you are lucky it will have the long flexible hydraulic hose to the oil cooler up front and there will be enough slack to split without disconnecting oil cooler hydraulic hose. The fuel line comes off the top of the first fuel filter, the return fuel line comes apart at the firewall by the battery box. Remove large electrical from battery first, the other electrical should have a molex connector under the battery box. Then there are bolts and studs around the bell housing, there are two under the battery box. To put it back together we usually just put pressure plate and clutch disk on the shafts, push tractor almost together so that studs and bolts in bell housing are threaded and then install pressure plate bolts to flywheel thru the inspection plate at the bottom.
BE VERY CAREFUL, make sure you have proper jacks and splitting stands.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
