The attached image is from the original manual and is the same as on the tractor. It is not a dual fuel unit and is same as the unit as shown in top of picture. The top idle adjusting screw does not seem to have any effect on engine idle. No matter where I set that adjusting screw the engine seems to run too rich.[Kicks out black smoke as if the choke is closed]. The plugs then carbon up and start to miss.
I have made sure the float is not leaking and the float valve seems to operate properly. I check this by moving float with base off and blowing through the fuel input line.
Its as if the replacement idle adjusting screw from the OEM repair kit is not doing what it is should be doing, controlling the amount of fuel at idle. So if its not controlling it at idle it likely is allowing fuel to get through the port at all engine speeds.
The screw measures 1.080" from the base of the head to the tip.
It appears the original carb was designed to handle two fuels [gas and kerosene]but perhaps does not do a good job at either!
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
