Posted by Duanes on September 16, 2010 at 12:34:34 from (136.234.40.2):
We have a Farmall Regular that has hot spark and feels like it has good compression. Tractor ran with original E4a mag and died when it got hot so, I assumed it had a bad coil and switched to A F4 that I had as a spare and had been tested. Hand cranked tractor and it started and ran but, was running hot and backfiring so, I figured the timing was retarded and after running a few minutes I shut it down. Before changing timing I tried to hand start and no success,pulled it and started and died. Pulled again and nothing and blew oil out of air cleaner. Put new coil in mag as someone suggested and will only pull start and we ran 5 minutes and it ran fine but, will not crank start. Any ideas what is wrong.?Anyway to check compression? Old timer I took it too says he feels like the compression is good but knows of no way to check with out starter. Thanks for any help! 9/16/10 New Post: Still have not solved the mystery. Will low compression cause the tractor to not be crank started? Is there a way to test the compression? Thanks
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
