Farmall M Final Drive & Rear Axle Bearing Questions
Posted by keithg on September 17, 2010 at 20:15:48 from (173.28.129.191):
I am currently working on a 47 M and looking at the inner/outer rear axle and bull pinion (brake) shaft bearings. I am curious how some of the forum members make the judgment call about replacing or reusing these bearings.
For example, I removed the entire wheel from the RH rear axle, placed a dial indicator on the axle next to the outer grease fitting, then raised and lowered the rear axle by hand............saw about 010" of movement, I assume due to original bearing radial clearance+wear in the outer bearing. Is this enough play to consider replacing this bearing? And will this amount of play prevent the new outer axle oil seal I am planning to install from actually sealing? Some of these bearings are expensive, at least through CaseIH.
I have the transmission cover off now so I can easily access all of these bearings. Tractor will be lightly used in the future, only rarely seeing full tractive load.
Thanks in advance for any pointers which may be provided.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
