To add 1/8" of bore, the sleeves are thinner therefore no block machining should be needed. The outside diameter of the new sleeves will be the same as your old ones. Take the old sleeves out and measure the inside diameter of the block at the bottom of the sleeve where the "O" Ring seal is. There was more than one diameter used there, depending on the vintage of the block. Once you know what you have, you can get exactly the sleeves you need.
I had a machinist make my "Puck".
There shouldn't be any interference issues going to high compression pistons unless someone has shaved a lot off the head previously. I had that problem on one head and solved it with a just a little bit of machining on the head. Turned out to be not a real big problem.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
