Posted by D Slater on September 18, 2010 at 18:10:08 from (184.15.13.17):
In Reply to: 400 Farmall TA posted by 400D tractorman on September 18, 2010 at 17:08:29:
If the clutch linkages are adjusted to the best they can be. The T/A clutch is not releasing or staying released. If the t/a clutch pressure plate and release bearing is good, check for lining comming loose on clutch plate or oil getting on it. Also check that the clutch carrier is not loose due to the retaining nut backing off. Other possibilities is a problem with the planet gears, shafts or bearings in the t/a unit that makes them not want to turn free when in t/a. If planet gears don't want to turn or lock up completly, the whole planet carrier unit turns as one unit just like in dirrect drive t/a even though the t/a clutch would be released. Another thing I was about to forget is sometimes the coupling between the t/a drive shaft and t/a sun gear shaft will slide back on the splines and keep pressure to the t/a clutch plate after release. They added a clip inside later splined couplings to keep that from happening.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
