Posted by truckinthumbtack on September 19, 2010 at 10:33:35 from (204.116.207.73):
In Reply to: installing bearings posted by hman on September 17, 2010 at 08:22:55:
You are referring to what is called as "rolling" them in. To remove them. Remove one main or rod cap at a time. Roll out the old bearing. This is done by pushing on the side of the bearing that does not have the notch on it. Use some thing soft that will not mar the crank!!! I.E. thin piece of plastic etc. When you get the old bearing out. On the back of it it will say "STD" if standard or .010 for undersizes, etc. Like the other gentlemen said though. Installation is reverse. If you need to do this, chances are the sleeves and pistons need attention too. Your crank may even be scored or as mentioned "egg shaped" to the point it needs turned anyhow. So you'd be wasting your time.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
