Farmall M - Rubber Washer on Brake Drum
Posted by Melvin Ware on September 20, 2010 at 06:15:57 from (4.88.53.143):
Rebuilding Brakes on my Farmall M I found there is a rubber washer that fits in a recess in the outer bore of the brake drum and rests against the end of the splines. It's maybe about a 1/16" thick. On top of this rubber washer is a somewhat larger metal washer that presses the rubber washer into the splines, maybe to prevent grease leakage there. The old washers are quite brittle and one broke apart upon removal. Any suggestions on what to replace these washers with?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
