Posted by doehmke on September 23, 2010 at 17:35:35 from (71.55.150.6):
What's the recommended way to install F-20 pistons? I have a set of used sleeves bored out to accomodate the original 4" pistons. They're pretty thin at the bottom of the skirt, so seem fragile for installing from the bottom if a ring gets hung-up. Also, is there a special type of ring compressor and/or technique to go from the bottom? Can you fit a mallet or hammer handle inside the block to tap them in? Or can they go in from the top w/4" cylinders? It seems like the crank end of the connecting rods wouldn't fit through the cylinder for standard size, but hoping that works for the larger 4" cylinder. The tractors is 3 hours away, so I'm going off memory for sizing things up.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
