Farmall H govenor and distribitor
Posted by Patrickl6080 on September 23, 2010 at 19:41:31 from (216.51.201.47):
I have a farmall h that has not ran for several years and am trying to get it going soaked carb and cleaned very good and put complete carb repair kit in got running. Starts and runs good but very poor throttle response. Looked at govenor and found binding throttle linkage fixed linkage problem and syncronized carb to govenor per tech manual trying to set high and low idle speeds per manual but very hard to get set. Seems like it either idles or wide open have to move throttle half way before tractor starts to speed up. Removed distribitor and checked for broken advance springs or stuck advance wheights noiticed dis springs are two different ones should they be this way and where can a person find new ones. Also looked at govenor brs and thrust washer all look ok and everything is free noticed when throttle at idle wheights are bolth free and I can wiggle them on pivot pins not like holes worn out just in and out a little like I belive they should but if throttle is wide open I can wiggle one wheight a little and the other one is tight dose anyone have any advice for dis or govenor Thanks
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
