A couple of observations just from the pictures and the notes so far.
First off, one of your Hs, the one that was backed on and up against the front of the trailer, has a battery igntition, not a magneto. It's a little unusual in that it has the upright Delco distributor rather than the stock IH horizontal arrangement.
As to the magnetos on the other two tractors, the points shou,ld be right under the dust cover inside the cap, the dust cover being the next thing you run into after removing the rotor button. The condenser is better seen by removing the top cap and looking down. The wire that runs back to the switch to ground out your mag to kill the engine looks to be missing on the SA but is right there on the side of the mag on the other H. The stud that grounding wire hooks to is threaded onto the top end of the condenser. It runs laterally across the body of the mag. Removal requires pulling the mag, removing the cover on top to loosen the simple clamp holding the condenser in lace, and then removing a cap on the back side to slide it out.
I've got an idea everything's there. Hope this helps you to locate it all.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
