The original setup had a 2 way cylinder, I believe. But the original parts are going to be hard to find. You can use a diversion fitting or valve that fits under the original tubes on the reservoir and run to a spool valve and on to the rear. These valves are readily available from several sources. The reservoir will have enough capacity for small implements, however capacity can be a problem for a large implement such as a loader as Gene says. I would think it would work on a small tandem disk, etc. You can use a double acting or single acting cylinder.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
