It is a common problem on older tractors, trucks, and even cars. The quick remedy on a tractor is to shut off the switch, put the tractor in gear, and rock the tractor by pushing against the rear tire. Usually you will hear a "click" from the starter, and then you are good to go. Sometimes that trick does not work, so then you get out your 3/4" wrench, loosen the bolts that hold the starter on enough so you can pull the starter back, and then you will hear the click. Tighten the bolts again and it's done. Eventually, you WILL need to replace the drive on the starter, and quite possibly split the tractor and replace the toothed ring gear on the flywheel. The ring gear is not expensive, but the work involved in getting to it can be, unless you do it yourself.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
