Posted by Janicholson on September 28, 2010 at 19:08:34 from (67.72.98.45):
In Reply to: Backlash, again posted by CNKS on September 28, 2010 at 18:54:38:
Putting it at .007 will be a good compromise. THey will make noise no matter what if they are used gears, and run with the lash close and the pinion depth good. The tooth pattern is more important on used gears than the lash, but with poor visibility the only choice is to be as close as possible. If the gears are 3" and the pinion is ~1.750 in radius at the pinion, an approximation is to double the lash when measuring at the gear. A good pattern is found by putting prussian blue on the gear teeth (pinion or ring) on the driven side, Put a weight or resistance on the ring gear and turn the pinion till the same tooth becomes visible again. The pattern should be centered on the face of the tooth, and blend outward to the edges from there. There are good examples on Google images ring gear wipe patterns. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
