Re: H charging problems....again
Posted by John T on September 29, 2010 at 05:07:35 from (66.244.97.31):
In Reply to: H charging problems....again posted by Fullers Farmall on September 28, 2010 at 19:29:52:
As long as the battery is being charged enough so she always starts, I wouldnt worry all that much just yet. It could be worn down brushes in the genny or sticking corroded brush hold down springys or burned carboned contacts in the Voltage Regulator (if it has one instead of simple cutout relay) or a bad grounded or worn switch contact in the LHBD switch if thats what it has (used with 2 wire simple cutout relay systems). Other minor problems may be a bad ground or a loose or corroded connection or even a loose fan belt.
If it gets to where it isnt charging at all run Par 5 of my Troubleshooting Procedure which will tell you if its a generator versus a Voltage Regulator or other problem.
For now Ima goin with the genny brushes are getting short or theres a bad ground or other connection (like a bad ground in the LHBD swith or it has resistive loose contacts) and if it happens to have a Voltage Regulator (instead of a simple cutout relay and LHBD ligh switch)it has burned carboned contacts or a bad ground.
John T
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
