Posted by rustyfarmall on October 02, 2010 at 08:11:10 from (209.152.78.140):
In Reply to: Farmall H Valve Train posted by Jeff Ferguson4 on October 02, 2010 at 08:05:44:
The valves are stuck in the guides. Spray penetrating oil on the stems, and then lightly tap on the top of the valve stem with a smaller hammer. Give each stem a few taps, and then walk away for awhile. Maybe an hour or so later, do it all over again. Eventually, those valves will loosen up and be O.K.
You will need to remove the rocker arm assembly to gain full access to the valves.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
