Posted by ScottyHOMEy on October 02, 2010 at 18:36:52 from (64.222.202.205):
In Reply to: Farmall Super A posted by Philip Rosenberg on October 01, 2010 at 05:09:01:
Before you tear it down to remove a piston, I'd set the valve clearances to see what you've got.
You haven't said what else you've done with the motor, but as another said, if it will turn over and even if the rings are stuck, you should get some level of compression once the valves are set properly.
Try that first. The shop that worked on your head can only put the parts back in place when it comes to valve/rocker clearances. Go over it, and you'll find them all over the place, from minor adjustments needed in or out, to completely out of whack in either direction.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
