Hi Jerry, the following is from Bernard le mecano, who used to be on this board frequently. He had many years as an IH Mechanic.
To prime the hydraulic pump, under the filter canister, there is a pipe for the steering supply, loosen the fitting and place a container to catch the oil, start the engine and check for oil flow at the fitting. Stop engine when there is oil flow. When the pump is worn, it's harder to prime the system. Bernard le mécano
If this dosen't work then there is a problem with the suction tube or "O" rings. Is the filter correctly installed? Filter next MCV and strainer next the cover?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
