Timing curves are designed to put a spark into the cylinder at just the instant that causes the flame front from the burning fuel (it does not explode)to reach full cylinder pressure at about 4 to 8 degrees after TDC. If it is too early, the pressure causes detonation as there is no where for the pressure to go. If late, the piston is too far down and speeding up such that the fuel has less to do. Chancing the springs may have changed this position in a way that makes less power for your fuel/work/RPM. I would make sure the timing is at TDC static, then check it with a light. to assess the point of full advance. I would guess it is at 1300RPM (but do not know the spec.). Try the old springs if it is timed at TDC static. Adjust it if it is not at TDC static. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
