Posted by JeffL on October 10, 2010 at 10:29:44 from (97.231.126.52):
I have a 350u with manual steering and front PTO pump (for loader) off the front of the crank (not the distributor gear style or belly style).
I bought the power steering parts from a 350u that had the belly style pump. Came from a junkyard and not sure it was working or not other than it did steer the tractor to move it around with no engine (bad block).
Anything I should do to test the power unit before I start? Anything I should replace as far as seals etc (I will use all new hoses for sure)? I was going to try testing it with air, then turn the steering shaft and see that the motor moves one way, then steer the other and see the motor move the other.
Not sure what pump to use:
I read other similar posts and found a 1965 ford mustang Eaton pump that i can buy working for $30. I can fab a bracket, i have a plasma cutter. Might just take off the generator and put the Eaton pump there to start with since the generator is not really keeping the battery charged anyway.
I saw a chrysler eaton pump with 6 volt delco generator combination for $100, but wasn't sure the eaton steering pump would be right though. It is two units with one pulley, that would bolt right up to the current generator bracket, i would probably have to use the guts from my 12V generator, and I don't know if they would be the same.
The other option would be to tee off the big pump, but as that one is used for loader and backhoe I am apprehensive about it. Also I would have to add some kind of valving for that I think, as I understand it the pressure regulation was down in the belly; and the Ford Eaton pump has it in there, and of course my big pump does not have that; relying on the control valve banks.
I looked at the power steering on my Super-M and see that there is an added front pump with a belt and it's own pulley. I thought maybe there was a way to add an extra pulley to my 350 and then leave the generator pulley separate.
I should mention that i use the thing to dig in tight places like my creekbed, and filling my 57 chevy 4 yard dump truck (yeah i still use it to haul stuff). it is never used for field duty, have other tractors for that.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
