Less work to restrict the valve exhaust port on a double acting cylinder. Probably not necessary anyway with the supply line regulator.
Not even sure a slow and smooth engagement is desirable although some of that will occur due to the medium and the springs inside the IPTO. Seems like slippage might promote band wear. At this point, I am thinking I'll want to run the cylinder at more than 40 lbs to insure there is no slippage when loaded. Adjustments will be needed depending on how many freezers are spinning and how much power the ice chipper draws. Tweaking of the system will occur at a much later date.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
