Posted by pete 23 on October 17, 2010 at 11:10:17 from (184.12.32.90):
In Reply to: 706d stalling posted by Russ from Canada on October 17, 2010 at 10:23:11:
Is it a 282 or 310? Eiether one, take line off at pump from filter to see if you get a good flow of fuel, if not work back toward tank. If ok, on a 282, take off the top fuel return line fitting, whole fitting out of top of pump and see if check valve has bits of plastic in it indicating failure of govenor shock absorbing ring. You could try running it without fitting, just to check to see if that is the problem. The 310 doesn't have that problem.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
