The voltage to which it can raise the battery (from 6.3 setting to near 7 and over) as Hal pointed out at RPM is a good charging test. Make sure the belt is good n tight and BOTH the Genny and VR (or headlight switch if its a cutout relay system) have good grounds. If when shes running you use a jumper to temporarily dead ground the gennys FLD post that allows for max charge independant of any Light Switch or Voltage Regulator problems so see how she charges then???? If she charges strong with the FLD post grounded but NOT otherwise the problems either in the LHBD light switch or the VR or the VR or switch has a bad/resistive ground.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
