Posted by Harold Hubbard on October 20, 2010 at 15:56:22 from (205.209.16.24):
Yesterday my C started misfiring and stumbling every time I let the clutch out, but it would smooth out and run right after it got moving. I was clipping a pasture with the sickle bar, and managed to finish up without it getting any worse.
So, this morning I dug into the distributor, expecting to find some moisture and maybe have to reset the points. Got it open and it was full of powdered rust, so I pulled it out for a complete disassembly and cleaning. I got it all clean, actually plugged the shaft bore and bead blasted the housing, and started re-assembling it. I pulled a new set of Genuine IH, made in USA points off the shelf, installed and gapped them, re-installed the distributor, and tried to dead time it. GAAA!!! NO CONTINUITY THROUGH THE NEW POINTS. Did the clean rag, clean paper thing, nothing, rubbed the points vigorously together, zip, cursed a lot. Just what I really want to do, file a brand new set of points to make them work, no. Finally gritted my teeth and hit them with a Scotch-brite disk on my die grinder, took two hits of that before I got a good contact.
Ten minute job wound up taking two hours, not all the fault of the points, they were just a bit of added aggravation when I thought was nearly finished. I guess I should just get the TSC, made in Mexico, points next time, at least I will be expecting them to screw up. The last pair of them I had snapped the spring, and the tractor stopped right there.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
